Community Member
RME config issue of C4990M
LMS Version 2.6
RME Version 4.0.6
we are facing RME config backup issue.
Currnetly running IOS
cat4500e-ipbasek9-mz.122-46.SG.bin
Please find the error below for cisco C4900M
CM0056 Config fetch failed for 10.108.133.11 Cause: CM0204 Could not create DeviceContext for 1103 Cause: CM0206 Could not get the config transport implementation for 10.108.133.11 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Vaibhav
1 REPLY
Re: RME config issue of C4990M
There is no support for a Catalyst 4990 in LMS. What is the exact sysObjectID of this device?
128
