Community Member
RME Custom Reports
I'm trying to create a custom report template so that I can capture asset details for the installed hardware. So far I can get the details for the chassis, linecards, and Sup card but I can't seem to find the variables which will report the details for the PSU's and Fan trays.
I need the information so that I can provide it to the 3rd party maintainer and I didn't want to spend the next month typing "show inventory" on each device.
I'm using the following expressions -
System:Name:equals:All
AND:Chassis:Chassis Model Name:equals:All
AND:Chassis:Chassis Serial Number:equals:All
AND:Processor:Model Name:equals:All
AND:Processor:Serial Number:equals:All
AND:Module:Model Name:equals:All
AND:Module:Serial Number:equals:All
AND:System:System Object ID:equals:All
Any help gratefully received.
Blue
Re: RME Custom Reports
You can have RME - Tools - NetShow do the "show inventory" for you though, up to 10 devices ad-hoc, or an "unlimited" (~300) number if scheduled.
Community Member
Thanks for that but I wanted the end result to be exportable either by pdf or csv.
Blue
That can be done: NMSROOT/bin/cwcli netshow jobresults -u admin -p admin -id Your-Job-ID-here
Community Member
Is there an equivalent Windows command string?
TIA
Blue
It should be the same:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.2/user/guide/cwcli.pdf
"On Windows systems, install_dir\CSCOpx\bin
The default install directory is C:\Program Files."
143
