RME DB question?
getwithrob
Level 3
Level 3
We are running RME only on one of our boxes and it seems to be starting to act kinda quirky.
Is there anything I can do to tell if the DB is starting to hose up? Is there anything I can do to correct those inconsistencies?
This is not a reinit in any way. However, before anything is done to the database, one should perform a backup.
6 Replies 6
nhabib
Level 9
Level 9
Here are the instructions to correct inconsistencies. Of course, make sure you perform a backup before running them.
You need to be root and using a Bourne or Korn shell
/etc/init.d/dmgtd stop
LD_LIBRARY_PATH=/opt/CSCOpx/lib:/opt/CSCOpx/objects/db/lib
export LD_LIBRARY_PATH
PATH=${PATH}:/opt/CSCOpx/objects/db/bin ; export PATH
SATMP=/tmp/.SQLAnywhere ; export SATMP
ASANY=/opt/CSCOpx/objects/db ; export ASANY
cd /opt/CSCOpx/databases/rme
rm rme.log (if it exists)
dbsrv7 -f rme.db
/etc/init.d/dmgtd start
I'm assuming this won't mess anything up...
It's not like a reinitdb or something is it?
I will do an online backup first, stop the db and run the commands. I just can't risk breaking anything!!!
Again, Thank you.
Again, Thank you.
