Webcast-Catalyst9k
RME devices vs CS devices
what is the difference between the devices on common services and RME devices? should I added the device after added to common services? or it did automatically? some devices not archived their startup..those device actually not on RME device list but they are on Common services.
Thanks in advance!!!
Re: RME devices vs CS devices
Common Services lists all devices in DCR. By default RME will attempt to manage all devices in DCR (but this can be disabled). For devices which are in DCR, but not managed by RME, you can go to RME > Devices > Device Management > RME Devices to add them.
Put simply, RME's device list is a subset of Common Services'. While the two counts may be identical, it is possible for CS to have more devices than RME.
thank you Sir!!
155
