RME Discovery
victoria.evans
Is there a known issue with RME that sometimes you can discover a device with the host name and if that doesn't works you can try using the IP address instead?
Joe Clarke
RME doesn't do any discovery. It relies on the information in DCR as to what devices it will manage, and what credentials it will use to manage them. RME will use the hostname or IP address information that you provide in DCR. It will prefer the IP address if it is configured.
