Webcast-Catalyst9k
RME: Error when doing NetConfig job
Hi there,
I was doing a NetConfig job just now. I made two jobs, and they set to run immediately. Now for the first time I get the error: "ERROR:RME_CDL1022:Failed while locking the device" on few devices. When I saw this error I thought it could be because I had two jobs running at the same time so I stopped one of them, but the errors are still coming...
I've google'd this error, and there's no result, does anyone know what this error means?
Another short question, is it possible to select all failed devices in NetConfig job, and create a new job with the failed devices included so I can run the job again?
Thanks a lot in advance... ;)
Re: RME: Error when doing NetConfig job
You might check under Common Services > Server > Admin > Resource Browser to see if there are any stale device locks.
If you retry a failed Netconfig job, only the failed devices will be retried.
There are no records under Resource Browser...
Any other ideas?
429
