Community Member
RME Filter Don't include 2006
When I try to run reports in RME/Change Audit for 2006, I don't have the option, year only goes up to 2005. Has anyone heard of a fix or upgrade for this?
Blue
Re: RME Filter Don't include 2006
If this is RME 3.5, then look very similar to CSCsc96446
Community Member
I do not see any update for this bug. Any idea when the new patch will come for this?.
Shivas
There is a patch available if you contact the TAC. I have tested it and it fixes this issue.
109
