Community Member
RME Group Administration Issues
Running LMS 2.6 RME 4.0.6
Hi all,
I'm trying to find a good way to create a group that specifies all of my CatOS switches. I've tried it a few different ways. No matter which way I try, the results only include about half of the devices that actually run CatOS. Here is the string I'm using:
Device.Image.Sys_Description contains "Catalyst"
If I grab a detailed device report for the missing devices the System Image Description field has the words "Catalyst Operating System". So I don't understand why the search isn't picking the devices up. Am I missing something here?
1 REPLY
Re: RME Group Administration Issues
Try matching on devices whose sysObjectIDs start with 1.3.6.1.4.1.9.5 or .1.3.6.1.4.1.9.5 depending on the application.
102
