Webcast-Catalyst9k
RME: partially successful devices
I recently updated the devices in CW 3.0.1.
out of 600 devices some 200 are now coming back with the following errors.
Command failedFailed to detect SSH version running on the device. VLAN Config fetch is not supported using TFTP. VLAN Config fetch is not supported using RCP.
None of the devices are running SSH.
1 REPLY
Re: RME: partially successful devices
The vlan.dat can only be fetched using telnet or SSH. If RME cannot connect to the device via one of those two protocols, this is the error you would see. Verify the correct username/password and enable password credentials in DCR for these devices.
280
