Community Member
RME softver repository problem
Hi!
I came on a snag when i tried the upload softvare from device to repository.
The job results shows the following:
Error Message:
SWIM1124: Failed to copy the image from Flash due to the reason - SWIM5004: Cannot initiate SNMP-set operation.
The SNMP Write Community String might be wrong.
I have checked many times and i run the management station to devices function and everything were ok.
The snmp debug on router shows there were not snmp set regquest from RME. I saw snmp get packets only. The RME asks the flash data ( partition, file names etc ) and nothing else. RME version 4.3.2
Eralier i used the default snmp communities w/o problem but now i had to change them.
1 ACCEPTED SOLUTION
Re: RME softver repository problem
Run a "Check Device Credential" job from Device Center for the RW community for this device.  If this fails, make sure the community is correct under CS > Device and Credentials > Device Management.  You can perform an export of the credentials to make sure they are correct.
Community Member
Hi Joel,
First of all i would like to thanks your answer.
The Check Device Credential shows the snmp communities rw was false.
I changed the communities so i clicked to device credentials button on  the Device Credentials Verification Job Details form.
The softver upload is working right now from this device.
Earlier i tried to run the management station to devices function and it was succcessful for SNMP RW!!!!!!!!!!!!!!!!!!!!!!!!!!!
I tried to change the commnities via CS > Device and Credentials > Device Management.
Despit all these the RME fetching was not working.
I do not unterstand what is the different .
The management station does not actually try to query the device using the community or login with the telnet/SSH credentials (just tests protocol), which is why you should use the "Check Device Credential" job instead when testing the credentials.
223
