Community Member
RME Syslog doesn't receive devices coldstart
hello all,
I don't receive Coldstart from my device when there is a reboot in my RME Syslog report 24 hours...
1 REPLY
Re: RME Syslog doesn't receive devices coldstart
The message may not actually be sent out on the wire due to the underlying network not yet being initialized (i.e. spanning tree, route convergeance, etc.). Check your syslog_info (Solaris) or syslog.log (Windows) to see if the messages are actually making it to the server. If they are, then SyslogCollector and/or SyslogAnalyzer debugging may be required. If not, then they are most likely being generated before they can be encapsulated on the wire.
103
