01-07-2009 10:14 AM
How do I delete/disable System Collection/Polling Schedule jobs?
Solved! Go to Solution.
01-08-2009 12:54 PM
Replace NMSROOT with the path into which CiscoWorks was installed. Run this command from a DOS shell as a local Administrator.
01-07-2009 10:36 AM
Inventory or Config?
01-07-2009 10:41 AM
Inventory...seems there wasn't one there. I added one and it told me ICSU0039: Successfully updated System Job Settings notification. I read a little further (!) and decided the size of my network would be better off collecting and polling inventory in smaller increments but couldn't find a way to back the job out or delete it.
01-07-2009 10:55 AM
Inventory collection and polling are always run. They cannot be disabled. You can configure collection to run in the distant future, however. Typically, we recommend inventory polling runs daily, and collection runs weekly. The overhead is typically minimal as this is just SNMP polling of containment information.
01-07-2009 11:10 AM
I cannot find evidence that they have ever run! Under Job Management>RME Jobs...no collection results. When I "updated" the default, there wasn't any information in the schedule fields, I added the day and time and my email(it didn't take what I submitted either...made 00:45:00 to 00:17:03)
01-07-2009 11:32 AM
Have you reinitialized your cmf database?
01-07-2009 11:48 AM
No, I don't know what this is...
BTW I am in a LMS class right now and you are famous! So happy to meet you!
01-07-2009 12:01 PM
This could be a jrm problem, then. What version of LMS is this? Please post the output of the pdshow command as well as the ICServerUI.log.
01-07-2009 12:26 PM
What LMS class are taking? I'd appreciate recommendations for training.
01-07-2009 01:11 PM
Global Knowledge: Implementing CiscoWorks LMS! Awesome class! Mike Fiedler is a rockstar of educators, passionate and knowledgeable, nothing close to Joe but highly recommended =-)
01-07-2009 01:03 PM
Sorry it took so long, communication to server is slow over VZ connection through VPN...
01-07-2009 01:38 PM
I need to see the ICServerUI.log as well.
01-07-2009 03:38 PM
It was part of the txt file
01-07-2009 11:12 PM
I must not have scrolled down far enough. However, the attachment appears to have gotten lost in the forum. Can you repost it?
01-08-2009 09:46 AM
