Webcast-Catalyst9k
Bronze
RME vs. ACE
Can we monitor & prepare reports about the ACE connections and probe using RME?
Abd Alqader
1 REPLY
Re: RME vs. ACE
There are no ACE-specific monitoring features of RME. You can run show commands on the ACE from RME's Netshow tool, and capture that output, but you cannot run reports on ACE-specific features per se.
134
