Webcast-Catalyst9k
RME with LMS 3.0
My customer work with RME 4.1 but he needed used the SSH when he use netconfig, that is possible??? When I use the netconfig, I do not see the option about SSH. Thanks for the answer.
regards
Guillermo
1 REPLY
Re: RME with LMS 3.0
Certainly Netconfig can use SSH. The protocol options for Netconfig can be found under RME > Admin > Config Mgmt > Transport Settings (select Netconfig as the Application Name).
98
