Community Member
RME3.5-IDU13-Solaris
Under RME> Administration> Configuration Mgmt> Network Show> Define Command Set -
Once a command set is defined, what directory and/or file(s) are the defined
command sets stored in?
The reason I ask is this: several command sets have been defined on 1 of the 3 RME servers. I would like to be able to just copy them from 1 server to the others....
1 ACCEPTED SOLUTION
Re: RME3.5-IDU13-Solaris
Command sets are stored in the RME database.
1 REPLY
98
