RMON for IP SLA on Cisco 2691
I am running IP SLA for udp-jitter operation (jitter/latency/RTT measure) on cisco 2691 router. I want RMON to be configured so that traps can be sent to NMS when crossing threshold. When i am creating RMON alarm for any "rttMonJitter*" operation , it gives me an error that it is a unknown object.
can someone suggest what shud be done in this scenario?
rgds
Re: RMON for IP SLA on Cisco 2691
Why use RMON? Why not use an IP SLA trigger to send a trap instead? You can configure a reaction type to occur when the average jitter crosses the threshold defined in your collector. The action can then be to send an rttMonNotification trap from the CISCO-RTTMON-MIB.
thanks for the response...
yes, i can certainly use reaction-trigger of IPSLA, but the problem is that i am having more than 500 IP SLA configured, so if i use reaction-trigger then it wud be for per SLA config..
if i use RMON, then it wud be general for all IP SLAs.
rgds
No, you'll still need to specify an index for the RMON alarm; so you'll need an RMON alarm for each collector. It would be easier to create the IP SLA reactions.
no, i don't require to give each index of IP SLA, that is common for all indexes..
rgds
There is no such object in the CISCO-RTTMON-MIB that will give you a combined or average jitter across all configured collectors. You will need to watch the jitter values for each collector individually.
hi,
just see this config:
rmon event 100 log trap public owner NNM
rmon alarm 10 rttMonLatestJitterOperRTTMax 40 absolute rising-threshold 5 100 falling-threshold 1 owner NNM
this will send the trap of each index of IP SLA to NMS
rgds
513
