Community Member
RMON traps sent as Syslog
I would like to pose you a question.
I have a 7200 router with image c7200-k4p-mz.120-31.S1.bin
When the wan link RMON threshold is reached, the router does send Syslog messages (sent to the logging server) and not traps (to the snmp-server host), despite the fact that the configuration does specify the trap.
I did also try with the log trap command but again, only a Syslog message is sent, not a trap to the snmp-server host list).
This has been verified with a Sniffer trace.
The RMON configuration looks like the following:
rmon event 10 trap public description "Rising Event for ifOutOctets" owner admin
rmon alarm 10 ifOutOctets.4 30 delta rising-threshold 10500000 10 falling-threshold 7500000 10 owner admin
Is this a bug, a misconfiguration or a "normal" behaviour?
snmp config:
snmp-server community <removed> RO 98
snmp-server community <removed> RW 99
snmp-server trap-source Loopback0
snmp-server packetsize 1024
snmp-server location answ
snmp-server contact
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps copy-config
snmp-server enable traps cpu threshold
snmp-server enable traps envmon
snmp-server enable traps syslog
snmp-server enable traps ospf state-change neighbor-state-change
snmp-server host <removed>
snmp-server tftp-server-list 21
So,there is nothing send to the SNMP server.How come?
Anyone who can help?
Config and snif trace can be provided.
Re: RMON traps sent as Syslog
conf t
snmp-server enable traps ?
What are all the options that show up?
