Route-map based ip policy not working
I have one 1841 routes with 2 internet providers (ADSL routers connected to 1841 FE interfaces).
One of those is primary and other serves as backup connection. Default route is 192.168.1.1 and secondary is 192.168.2.1
I want to route all traffic from specific local hosts to secondary ISP, while maintaining all the rest through primary ISP. Used route-map based ip policy.
My problem is that policy seems to work OK for all traffic except POP3 and some IM applications.
Any clue about where may be the problem? My configuration follows:
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.2.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Vlan1
description LAN$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
ip nat inside
zone-member security in-zone
ip policy route-map ALPI
ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 123
ip route 0.0.0.0 0.0.0.0 192.168.2.1 250
access-list 109 permit ip host 192.168.0.66 any
route-map ALPI permit 10
match ip address 109
set ip next-hop 192.168.2.1
Thanks in advance for your help,
Albert Moran
Hall of Fame Super Silver
Re: Route-map based ip policy not working
After you posted this question in this forum you then posted this question in the WAN Routing and Switching forum where I have posted an answer. I suggest that any further discussion be consolidated in that forum.
Rick
Sorry about the double post. At first I did not see my own post and though it was not sent correctly (my fault). When re-sending it, considered the other forum as more adequate.
Albert
222
