Routers and Switches Uptimes
Does anyone know, what are the recomended uptimes for Cisco routers and switches? I believe the it depends on Model/Type.  After how long does a switch or a router needs to be rebooted? If possible, provide me with a list for all models or let me know where I could find this information.
Thank you
Everyone's tags (4)
Re: Routers and Switches Uptimes
Hi Parul,
There's no as such recommended uptime as these equipments are quite robust, what you might consider is the memory utilization on the box from time to time and decide weather the unit needs a reload or not, a reload will free up all the unused memory.
You can run the following commands to check the current utilization:
sh mem summary
sh proc mem
(common for both switches and routers)
Thank you for your response Gaurav. I certainly will consider this
suggestion.
Take care
Parul Patel
Brown Brothers Harriman & Co.
Enterprise Communications
Work | 201-418-8014
Cell | 201-682-8525
To: Parul Patel ,
Date: 01/27/2012 06:15 AM
Subject: - Re: Routers and Switches Uptimes
Home
created by Gaurav Joshi in Network Management - View the full discussion
Hi Parul,
Reply to this message by going to Home
Start a new discussion in Network Management at Home
                                                      • IMPORTANT
NOTE*****************************-- The opinions expressed in this
message and/or any attachments are those of the author and not
necessarily those of Brown Brothers Harriman & Co., its
subsidiaries and affiliates ("BBH"). There is no guarantee that
this message is either private or confidential, and it may have
been altered by unauthorized sources without your or our knowledge.
Nothing in the message is capable or intended to create any legally
binding obligations on either party and it is not intended to
provide legal advice. BBH accepts no responsibility for loss or
damage from its use, including damage from virus.
495
