Community Member
rspan problem on cisco 3750
Can you look at my configuration
The monitor session don't seem to be working
1)All port are on vlan1
2)Gi1/0/23 is where the sniffer is .
Router config -3750
vlan 99
name RSPAN-s
remote-span
monitor session 1 source vlan 1
monitor session 1 destination remote vlan 99
monitor session 2 source remote vlan 99
monitor session 2 destination interface Gi1/0/23
Silver
Re: rspan problem on cisco 3750
This is not allowed, an RSPAN destination session and an RSPAN source session that are using the same RSPAN VLAN cannot run on the same switch stack.
Hope this helps
Community Member
How can I do it ? Can you give me a example . I have two switch and I want to forward all traffic from two switch to one port in switch A .
Community Member
i have 2 3750 switches and i want one port on one 3750 to work as destination port and i want all vlan 1 on same switch to be working as source port and also you want all vlan 1 on other 3750 to send their traffic to destination port which is already configured on other 3750.
it is possible via RSPAN ?
can you give me a example
198
