I want to capture all traffic in a certain vlan (74) from two switches. I use a remote vlan to accomplish this.
The problem is that I see on the wireshark trace traffic which is traveling from one switch to the other but I don’t see traffic which remains within one switch.
So:
switch 1: server 1&2
switch 2: server 3&4
all interfaces in the same vlan (74)
remote vlan = vlan 745
connection switch 1 -> switch 2 = trunk (vlan 74 & 745)
action - on wireshark trace
ping server1 <-> sever 2 - no
ping server1<-> server 3 - yes
ping server 3 <-> server4 - no
I found some examples for the configuration and these are more or less the same as mine; so why is this not working as expected?
My config:
Switch 1 (3560)
monitor session 1 source vlan 74 rx
monitor session 1 destination remote vlan 745
switch 2 (4948)
monitor session 2 destination interface Gi1/17
monitor session 2 source remote vlan 745
Wireshark pc on port 17
Thanks for any help
Hans
