Running Ciscoworks LMS3.2 on x86/x64
Dear Friends,
I recently purchased some Sunfire X4140 X64 servers believing that I will be able to run my LMS3.2 on the servers.
I intended to install Solaris 10 and then LMS3.2 on top.
However when I try to install the LMS I get the following message:
INFO: Checking DHCP..
INFO: DHCP not enabled in this machine.
INFO: BUILD_ID is SOL_LMS3_2_CH_20090529_0001
INFO: ITOOLS_BUILD_ID is SOL_ITOOLS33_20090424_2302
ERROR: The server architecture is as follows -
ERROR: 32-bit i386 applications
ERROR:  amd_lzcnt popcnt amd_sse4a tscp cx16 mon sse3 sse2 sse fxsr amd_3dnowx
ERROR:  amd_3dnow amd_mmx mmx cmov sep cx8 tsc fpu
ERROR: This is not a supported architecture.
ERROR: The server architecture should be 32-bit compatible.
ERROR: The product cannot be installed on this server.
Finished:  Thu Jan 21 09:26:15 SAST 2010
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
bash-3.00#
Has anyone had a similar problem? Is there a possibility that LMS3.2 will run on X86/X64 hardware? If someone has encountered this problem how did they go round this issue. I did not intend to run the Windows version of the same.
I welcome any comments and suggests as I am at my wits end.
Gibson
Re: Running Ciscoworks LMS3.2 on x86/x64
Only a few solaris 10 versions are supported
The following Solaris 10 releases are supported in LMS 3.2:
Solaris 10, 10/08 release
Solaris 10, 05/08 release
Solaris 10, 08/07 release
Solaris 10, 11/06 release
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1099303
And there are some other restrictions mentioned and some patches.
If it is not that then I guess you need to open an SR.
Cheers,
Michel
LMS is not supported on Solaris running on x86 processors and I doubt it will...
have a look at the FAQ section in this document:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/faqs.html#wp1313830
Q. Is LMS 3.2 supported on Solaris x86 (on the x86 CPU)?
A. No, LMS 3.2 is not supported on Solaris x86.
it is also very well documented here:
hhttp://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1114662
with a list of supported processors and releases for Solaris:
The following are the supported processors on a Solaris system:
UltraSPARC III
UltraSPARC IIIi processor
UltraSPARC IV processor
UltraSPARC IV+ processor
UltraSPARC T1 processor
UltraSPARC T2 processor
UltraSPARC T2+ processor (Supported only on Solaris 10)
SPARC64 VI processor (Supported only on Solaris 10)
SPARC64 VII processor (Supported only on Solaris 10)
It seems you are running out of options. There is nothing which can make LMS to be installed in a x64 architecture.
The available options are restricted to choose between Win (x86/x64 both) or Sol 10 (x86), supported versions only.
This is a because even if you get something now to tweak around and pass through, in future if there will be any other issues the TAC would guide you to re-install the software on supported platform.
-thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
798
