Running config archive failed-RME 3.5
I am using Ciscoworks LMS 2.2,Windows.
Problem: Ciscowokrs not able to get pull the running configuration for few of the nodes
Error Displayed beside the failed devices is
"Telnet :No telnet passowrds in RME databases Tftp:PGM_NMConfiguration Archive=6717Type=Unassigned message type::Timeout error, snmp operation failed,ssh,no username and password in ME database."
But I could do for more than 60 nodes,only five nodes is having this problem
SNMP,ICMP telnet TFTP is configured properly ,I can telnet in to network nodes from command prompt and also run SNMPwalk from command everything looks successful,All the nodes are tied with tacacus,I also added the tacacus username and password in the tacacus.ini.
Can some one help me in solving this problem?
  • Network Management
1 REPLY
Silver
Re: Running config archive failed-RME 3.5
You will get this error if there is a mismatch in the authentication credentials. Check if the authentication credentials are configured correctly.
113
