Running Logrot
I have tried to manage the log file by using Logrot but unsuccessful. I just use the default size for backup 1024. do I need more? I don't want a big size...
I have attached the output. thanks in Advance
Re: Running Logrot
According to this, none of the log files are big enough for rotation. That said, logrot_stat is not working correctly. Assuming these files are actually over 4 GB, what do you get when you run:
/opt/CSCOpx/bin/logrot_stat FILE
Re: Running Logrot
I have attached the stat result, my biggest concern is my hard drive space in one week from 57% jump to 87% so I'm wondering something I should also check.I have upgrade to CM 3.6 and CS 4.11.last week. may be any temp file need to be clean.
thank you so much J.
Re: Running Logrot
Re: Running Logrot
Well, none of these log files are causing your disk space problems. If you're having a problem with space under /var, you can use du to find where that space has gone:
# for i in `ls -1 /var`; do
du -sh ${i}
done
Repeat the procedure once you've located the directory using the most space. Eventually, you'll find where all the space has gone.
Re: Running Logrot
thank you J. I'm on 67% !!! great help!!
156
