Running the perl logrot.pl -v
dionjiles
I pretty much understand the concept of running the perl logrot.pl -v and -c to minimize the syslog.log files. It is any way I can get to run in a batch file or script to run on a certain schedule or does this has to be done manually? Just curious I'm still learning the product.
Joe Clarke
You can schedule it using cron on UNIX or at on Windows.
Once you've verified things work on-demand, you can setup cron on UNIX:
0 1 * * * /opt/CSCOpx/bin/logrot.pl 2>&1 | /usr/lib/sendmail root
or AT on Windows:
at 01:00 /every:M,T,W,Th,F,S,Su C:\progra~1\CSCOpx\bin\perl.exe C:\progra~1\CSCOpx\bin\logrot.pl
(This assumes CiscoWorks is installed in the default location on Windows.)
Those commands will run logrot every day at 1:00 AM. The UNIX cron line will
also send all output of the command to root via email.
Thanks, once again I knew I would find the answer here.
