Community Member
SAA configuration using snmp
Hi to all,
I have some problem with creating IP SLA operations using SNMP.
As you know, to create the operation i need to set a rttMonCtrlAdminStatus to CreateAndWait(4) value. It works with devices IOS 12.1(3) but i cant set this value to devices IOS Software v12.4.
What is this problem may be related to?
Thanks ahead
Re: SAA configuration using snmp
What error message are you receiving?
From what I see for this object CreateAndWait is 5
Community Member
In both cases(createAndGo and createAndWait) occurs such snmp error: BER API ? Overflow.
142
