Webcast-Catalyst9k
SCABB - Problem with Updating CM
I have problem with CM update when send a new package to SCE.
SCABB return the follow message: Updating CM <CM IP Address> with service configuration timed out. Operation proceed in the backgroung.
How I could resolve this problem?
Silver
Re: SCABB - Problem with Updating CM
The CM May not be processing and inserting RDR's into the DB, and all RDR's are being
deleted before written to the DB.Something is using a lot of your port 4100 connections
Please go through this checklist and check if these
have been done:
1.RDR-Formatter destination is not configured on the SCE (to point to the CM)
2.No policy apply operation was made after RDR-Formatter destination was first set.
3.FW prevents policy update from the SCA-BB console to the CM.
4.DB was not installed correctly.
Hello ~ I am having a similar problem with a SE 1000 ... Can you take a look at the following:
https://supportforums.cisco.com/thread/346065
By the way ... I am running version 2.5.10 ... yes. I know ... quite old.
315
作成コンテンツを作成するには してください
