05-02-2006 08:09 PM
I have a network with approx 8000 devices. Ideally I need to see a view of the entire network. Ciscoworks doco states that it has a limitation of 5000. Except for segmenting the network into different management areas does anyone have any suggestions?
05-05-2006 06:59 AM
I am getting set to do just this.
I have about 10,000 devices. I would get the "LMS 2.5 Large Scale Deployment Design Paper.pdf" from Cisco, lots of good info in there.
Once you have over 5000 devices you will need multiple servers. Here is what I plan to do
Box #1 Runs Common Services and DCR only and is the master DCR and SSO server
Box #2 Runs Common Services and RME and is a slave SSO
Box #3 Runs Common Services and RME and is a slave SSO
Box #4,5,6,7 Runs Common Services and Campus Manager and is a slave SSO
Box #8,9,10,11 Runs Common Services and DFM and is a slave SSO
05-05-2006 07:02 AM
One more thing. I am running LMS 2.5.1. This will ot work if you are on not on 2.5.1
05-07-2006 03:49 PM
I have 7 servers planned for an almost identical scenario. BUT, does the 5000 device limit apply when a common DCR is used across multiple servers?
This is the one thing that I am not sure of from the Large scale deployment guide. Our local Cisco Ciscoworks person said that the 5000 limit still applies. hmmm
05-08-2006 12:12 PM
My understanding is that a stand-alone DCR can scale to 50,000 devices, but this is only if the server only runs Common Services and acts as a DCR and SSO server. The standard limits still apply to the remaining apps. RME on a seperate box from the DCR still has a limit of 5000 devices.
05-08-2006 02:42 PM
So what your saying is that if the following:
The DCR should only run Common Services to scale past 5000 devices. This means that if you wish to see the entire network from a global view you cannot since you need to install RME on the master to view everything. But RME will not support more than 5000 devices. You need to go to the individual servers to view and perform the different tasks.
This to me means that you are no better off by running this scenario. It would make just as much sense to run standalone servers.
Is there a benefit in having a common DCR if I exceed the 5000 limit?
Do I have this right?
