Netconfig is the way. A pre-built template to do reloads is coming in LMS 3.0, but for now, you can build an ad hoc template to do what you need. Something like:
reload
Should work provided the config has already been saved. If you need to add other responses, think of as "response to follow." If the response can be just a carriage return, you can leave the text after empty.
