08-25-2009 02:40 AM
I'm looking for a way to get Cisco Works configure vlans on several ports on a list of switches.
This list would look somewhat like:
switch1 - interface fa0/1 - vlan10
switch1 - interface fa0/3 - vlan20
switch5 - interface fa0/25 - vlan2
...etc
Can it be done?
Best regards,
Erik
08-25-2009 03:26 AM
Yes you can, with Campus Manager you're able to configure vlans for multiple ports in different switches within a VTP domain. As long as you have setup SNMP RW access in the DCR
08-25-2009 04:26 AM
Thanks Frank,
Yes i know Vlan port assignment, but how can it be done with an input file containing the values?
This file contains about 400 switches, each containing about 20 vlan port assignments.
Is Cisco Works capable of doing some sort of scripting?
Erik
08-25-2009 04:57 AM
yes, with RME cwcli and an xml input file this can be achieved
And in the new RME 4.3.0 (shipped with LMS 3.2) new port/module configuration is added.
