SDM: How to Tell Who is Logged In With
If I SSH to a router - is there a command that tells me if anyone is currently managing (or recently managed) the router via SDM?
1 ACCEPTED SOLUTION
Blue
Re: SDM: How to Tell Who is Logged In With
Since SDM uses HTTPS, theoretically one can search for TCP port 443 conversations with one of the router's interface ip addrs as the src or dst on a netflow-enabled router, under the assumption that those are SDM sessionis.
show ip cache flow | include ( xxx\.xxx\.xxx\.xxx * 443 )
Silver
Cisco SDM helps Cisco partners and customers securely (using SSL and SSH) and remotely manage all critical aspects of router operations: hardware and software inventory status, interface status, firewall and ACL logs, VPN tunnel status, and most recent syslog messages.
Blue
104
