Community Member
SDM on 3620?
I am wondering if it is possible to install Security Device manager on a 3620 router? I found a PDF file on ciscos site that has instructions on how to install SDM, and it states that it is compatible with the 3620, but I followed the instructions, and it doesn't seem like things are working right.
When I go to cisco's software advisor and look at features for 3620, it doesn't show SDM as an option.
I am confused, it looks like to me it doesn't work on the 3620?
1 REPLY
Re: SDM on 3620?
I feel as per your conclusion its not supported in 3620,the data sheet for SDM does confirms that.
And again the model 3620 and 3640 has reached EOL or EOS stage i feel its not there for those boxes..
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_data_sheet0900aecd800fd118.html
http://www.cisco.com/en/US/products/hw/routers/ps274/ps276/index.html
regds
262
