Webcast-Catalyst9k
Searching through CiscoWorks
Experts,
In CiscoWorks LMS 3.1 with RME 4.1.1, how do I perform the following:
a) search for specific device modesl (i.e. Catalyst 6506-E)
b) search for specific IOS versions
c) search for specific message types like "link flap", "eigrp neibor relationship", etc.
k0rg
1 REPLY
Re: Searching through CiscoWorks
For the first two, you can define inventory custom reports under RME > Reports > Custom Report Templates.
For the last one, you can define a custom syslog report using the same workflow as the inventory reports.
148
