08-12-2007 07:56 PM
Is there a maximum limit to the number of entries that can be added to the seed device file for device discovery in Campus Manager 4.0.9?
Ideally, I'd like to use the seed file from my NMS so that I have defined most of the devices to discover but it also gives scope to discover any that may have been missed - if I proceed with this, I'd be using a seed device file of 1064 devices.
Or does that sound a little too adventurous?
I'm upgrading from LMS 2.2 to 2.6 on new hardware and would prefer to re-discover the devices rather than a straight out import from the old system.
Thanks for any replies
Solved! Go to Solution.
08-12-2007 09:30 PM
Hi Claire,
maybe this link and the following five answers from jossy and questions from mermel
helps to clarify some things.
Best regards,
Frank
08-12-2007 09:30 PM
Hi Claire,
Best regards,
Frank
08-12-2007 10:03 PM
Hi Frank,
Thanks for your reply.
Great link, not only did it answer my question but jossy's explanation clarified things further.
I had searched earlier but didn't see that thread.
cheers,
Claire
