select problem with dbreader
I am trying to execute a query via dbreader and everytime I input my sql statement, it gives me a error and changes the * to \*.
Red
Re: select problem with dbreader
If you are running LMS 2.2 (CS 2.2 + RME 3.5), backup up the following file:
NMSROOT/cgi-bin/dbadmin/pdbadmin/nph-dbreader.pl
Edit nph-dbreader.pl and insert the following line after line 50:
$stmt =~ s/\\//g;
That should take care of the issue you are running into.
Just to be sure I don't screw this up, what does line 50 say so I make sure I am in the right spot.
Red
Looks like line 50 is:
$stmt = $input{'stmt'};
That worked. Thanks so much.
Red
Glad I could help.
136
