Selftest info
my UT application doesn't add nor delete records to the database and I'm wondering whether it may have to do with some of the following errors found running a selftest.
ERROR: pkgchk CSCOcmani failed.
ERROR: /opt/CSCOpx/backup/manifest/campus/database/ani.txt permissions <0640> expected <0750> actual
ERROR: pkgchk CSCOmd failed.
ERROR: /tmp/.SQLAnywhere permissions <0770> expected <0777> actual
1 REPLY
Re: Selftest info
No, these errors have nothing to do with the problem you describe. To debug UT problems finding MAC addresses, you should enable vmpsadmin debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new UT acquisition. Check the ut.log for errors.
Debugging problems removing entries is a bit more complicated, and you should work with the TAC to enable debugging there.
113
