sending remote commands from cat6500?
ronshuster
I have 2 CAT6500 connected to each other with etherchannel. The issue I am facing is that all the vty sessions are used on one of them.. does anyone know a way to send commands from one CAT6500 to the other one. Both cores are up and running and doing what they're supposed to do.
Any ideas?
Joe Clarke
At this point, you'll need to free up the vty lines from the switch's console. That is:
clear line TTY_NO
Alternatively, if you have SNMP read-write access to the switch, you can try clearing the lines using http://www.cisco.com/en/US/tech/tk648/tk362/technologies_problem_troubleshooting09186a00802b93ef.shtml .
