Setting up another Email to send syslog events to
I have followed the directions on http://www.cisco.com/en/US/products/sw/cscowork/ps2421/products_user_guide_chapter09186a00804fc54a.html to setup DFM to forward syslog events to my email. These current settings are not working at all. Here are my settings.
Summary from Syslog Notification
Subscription Name: TEST
Notification Group: Test
Facility: Local Use 7
Recipient(s): Hostname Port Comments
syslog 162
Notification Group Summary: Edit
Notification Group Name: Test
Device List: 192.168.111.15 ; 192.168.109.16 ; 192.168.109.15 ; 192.168.102.2 ; 205.250.5.15 ; 198.190.47.16 ; 198.190.47.15 ; 192.168.109.249 ; 192.168.109.248 ; 192.168.100.2 ; 192.168.109.247 ; 192.168.109.246 ; 192.168.89.6 ;
Alarm Status: Active ; ACK ; Cleared ;
Event Set: C
Event Severity: Critical ; Warning ; Informational ;
Event Status: Active ; Cleared ;
Customer Identification: Test
Customer Revision: 2
1 REPLY
Re: Setting up another Email to send syslog events to
It seems you have confused syslog and SNMP traps. DFM does not process syslog messages, so it will not be able to forward syslog messages via email. RME's Automated Action feature has this capability. See the online help under RME > Tools > Syslog > Automated Actions for more details on that.
What DFM will allow you to do is convert the events and alerts you see in the DFM Alerts and Activities Display into email messages. For this to work, you will need to create an Email notification subscription in DFM, and specify your email address as the recipient. You can use the same notification group, but you might want to consider NOT sending alerts if you are sending events. An event marks an individual device problem where as an alert rolls up multiple events for a given device. By sending both, you will see emails that appear to be duplicates.
121
CriarFaça o para criar o conteúdo
