08-18-2007 03:38 AM
I'm having a difficult time this morning finding what version of Rtr IOS software the "show interface description" command was released in?
Can someone point me down the right path?
thank you.
Solved! Go to Solution.
08-18-2007 06:51 AM
The correct syntax is "show interfaces description" with an "s", and here you are a couple of documents:
HTH,
Mohammed Mahmoud.
08-18-2007 06:51 AM
HTH,
Mohammed Mahmoud.
