Community Member
show policy-map interface | Question about QOS show command output
I hope this is the correct place for this question. If not, please let me know.
When I issue the show policy-map interface command (in this case on a  3845) there is some output I don't understand.  I have included some output below and formatted the lines I am confused about as "computer code" which show up as red on my screen.  A list of the individual lines i'm confused about is below, followed by those liens in the context of the show policy-map command's output.
Any help with this will be greatly appreciated. Thanks in advance.
5 minute offered rate 46000 bps, drop rate 0 bps
 5 minute rate 10000 bps
 bandwidth remaining 50% (768 kbps)
--- previous output omitted ---
GigabitEthernet0/0
  Service-policy input: QoS_IN
class-map: Silver (match-any)
      164691299 packets, 23570752398 bytes
      Match: access-group name MAINFRAME
        4371992 packets, 2311242335 bytes
        5 minute rate 0 bps
      Match: access-group name KRONOS
        13334297 packets, 3051409140 bytes
        5 minute rate 5000 bps
      Match: access-group name EMAIL
        97652823 packets, 10323856470 bytes
      Match: access-group name VOIP-CONTROL
        20782858 packets, 1481676784 bytes
        5 minute rate 0 bps
      Match: access-group name LOGIXWEB
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: access-group name GRINDLOG
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: access-group name CITRIX
        46895 packets, 14669179 bytes
        5 minute rate 0 bps
      Match: access-group name CORP_WEB
        28502414 packets, 6387897396 bytes
        5 minute rate 4000 bps
      QoS Set
        dscp af31
          Packets marked 164691269
show policy-map interface s0/0/0:0
Serial0/0/0:0
  Service-policy output: QoS_OUT
    Class-map: Silver (match-any)
      86590227 packets, 12051546524 bytes
      5 minute offered rate 3000 bps, drop rate 0 bps
        7641084 packets, 2701232492 bytes
        5 minute rate 0 bps
        6975052 packets, 1555404656 bytes
        5 minute rate 0 bps
        58438150 packets, 5433636586 bytes
        5 minute rate 3000 bps
        355083 packets, 41252455 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        19 packets, 4967 bytes
        5 minute rate 0 bps
        13180836 packets, 2320015236 bytes
        5 minute rate 0 bps
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/18156/0
      (pkts output/bytes output) 86421413/12004278837
Everyone's tags (6)
1410
