02-04-2008 03:26 AM
Hi guys, this could be a really simple fix but i cant seem to find the answer im looking for.
For some reason in the last week or so, when i do a "show run" command on my cisco PIX 515E instead of it just showing one page at a time and allowing me to either use enter/spacebar to scroll down through the config, it just displays the whole config in one go without stopping.
How can i stop this happening? It annoying becuase its a large config and in putty i am unable to see the settings towards the start of the config.
Can anyone shed some light?
Cheers
Simon
02-04-2008 04:33 AM
you need command
pager
ie pager 200 would allow 200 lines before the --more-- prompt
I use pager 24
M.
BTW you can increase scroll line buffer in putty (window --> lines of scrollback --> 200 is default that is not enough in most cases -- I use 2000)
Hope that helps rate if it does
02-04-2008 04:41 AM
Pager 24 is perfect
Thanks very much
Simon
