Slot mib confusion
I have two identical 4506 switches with regard to IOS 12.2(31)SG, bootstrap 12.2(20r)EW1 and module types in slot 2 of the chassis. While trying to write a scrit to pull the serial and type of each card installed I ran into the following.
(GOOD)
snmpwalk -v2c -c chw14 Host 1 .1.3.6.1.2.1.47.1.1.1.1.11.2000
SNMPv2-SMI::mib-2.47.1.1.1.1.11.2000 = STRING: "JAE10296RAC"
(BAD)
snmpwalk -v2c -c chw14 Host 2 .1.3.6.1.2.1.47.1.1.1.1.11.2000
SNMPv2-SMI::mib-2.47.1.1.1.1.11.2000 = No Such Instance currently exists at this OID
(HOST1)sh mod
<snip>
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE0948R1JZ
2 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE10296RAC
(Host2) sho mod
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE0948R1M7
2 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE10296R9Z
is the index number dynamically created on order of insertion, and why would Host2 sho me slot 2 information with an index of 4000?
1 REPLY
Re: Slot mib confusion
Yes, the index is obtained dynamically, and there are no rules listed in the MIB as to what this index needs to be. The textual convention states:
"An arbitrary value which uniquely identifies the physical entity. The value should be a small positive integer; index values for different physical entities are not necessarily contiguous."
110
