Community Member
Slowness in DFM create view
in the DFM 2.0.5 server under the Configuration:Other-Configurations Alerts and Activities Defaults- When I create a view, It takes long time to open also after click on create button
Re: Slowness in DFM create view
What is a long time exactly? What are the specs on your server and client? How many other views do you have created?
Community Member
It takes 4 min exactly when I click Alerts and Activies Default and also 4 min when i click Create.
This is the first view I want to create.
Number of devices in DFM only 56 devices
Number of devices in DCR 3200+
and DFM server it runs on separate server with salve mode.
server specification:
Sun Fire V210 2 cpu 1.3 Ghz, 8 GB of memory
Regarding space please find below the details:
Filesystem kbytes used avail capacity Mounted on
/dev/md/dsk/d0 16526762 5787795 10573700 36% /
/proc 0 0 0 0% /proc
mnttab 0 0 0 0% /etc/mnttab
fd 0 0 0 0% /dev/fd
swap 22294720 8 22294712 1% /var/run
swap 22294792 80 22294712 1% /tmp
/dev/md/dsk/d6 37183076 628369 36182877 2% /scratch
The slowness most likely stems from the number of devices in DCR. While I see a bit of slowness on my server, I do not have nearly the same number of devices in DCR, so it takes much less than four minutes to bring up the screens.
I did not find any bugs related to this slowness, so I recommend you open a TAC Service Request so a new one can be filed. Some additional VGM debugging may also be required to isolate exactly where in the code path the slowdown is occurring.
Community Member
Now It solved with LMS 2.6 Update.
