Webcast-Catalyst9k
SMI2 replacement for whyReload
Is there something I can do to fetch reload cause using SMI2/compatible MIBs, not the old OLD-CISCO-SYS-MIB?
Thanks in advance.
1 REPLY
Re: SMI2 replacement for whyReload
Although the OLD-CISCO-SYS-MIB is deprecated there is no replacement for whyReload. This object would still be used for IOS.
161
