01-23-2008 04:14 AM
Hi there, i have a high cpu problem in cisco 7609. I have excluded the ip.21,ip.22 and at to stop the nms from polling the routing table and the arp table, but the high cpu load still goes on. I have sniffed a huge number of get-request from some NMS and seems that the checksum is incorrect printing a "maybe caused by UDP checksum offload"message. The polling takes place every 4 minutes and has to do with the router's interfaces,protocols and mpls etc, but the load happens at unexpected times!.Does anyone know what might be going on?Is there any other object's i have to exclude in order to stop the cpu load?
01-23-2008 06:07 AM
Do you see any CPUHOG messages in the logs or any messages that indicates which OID is polled?
What do you see in show logging history?
01-23-2008 06:34 AM
Hi there, no logging regarding snmp exists! I suddenly have a snmp-engine to 100% and then it suddenly stops no log no nothing!
