Community Member
SNMP MIB - 3750 SWITCH
Hi Community,
we would like to monitor a 3750 switch for the below parameters. can you please advise which MIB should we download for that  ( please provide the exact name ) ? does it need a specific account to be able to download them ? thanks for the help.
thanks.
Jean
Cisco Switch 3750
H/W  MonitoringLAN switch fan  failure
H/W  MonitoringLAN Switch Memory  failure
H/W  MonitoringLAN Switch CPU  failure
H/W  MonitoringLAN switch memory  utilization
H/W  MonitoringLAN switch CPU utilization
H/W  MonitoringLAN switch CPU Utilization  %
H/W  MonitoringLAN Switch Memory Utilization  %
H/W  MonitoringLAN switch Port traffic  utilization (For each port with naming the destination) %
H/W  MonitoringLAN Switch  Failure
H/W  MonitoringLAN Switch Port  Failure
H/W  MonitoringLAN Switch Power Supply  Failure
1 REPLY
Re: SNMP MIB - 3750 SWITCH
It looks like the following MIBs will give you what you want:
RFC1213-MIB.my
IF-MIB.my
CISCO-ENVMON-MIB.my
CISCO-PROCESS-MIB.my
CISCO-MEMORY-POOL.my
All MIBs can be downloaded without a Cisco.com account from http://www.cisco.com/go/mibs using the MIB Locator.  In fact, it might be a good idea to download all the MIBs supported by your version of 3750 code.
3547
