02-09-2007 10:03 AM
I noticed an SNMP MIB output discrepancy with Cisco 6500 running IOS
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF4, RELEASE SOFTWARE (fc1)
Basically, if I snmpwalk .1.3.6.1.2.1.2.2.1.2
I see my 137 interfaces on the switch. That being the case. I should see the output of walking .1.3.6.1.2.1.2.1.0 as 137. However, my output says 133. These MIBs match up perfectly on my other Cisco Switches. Is this a bug?
Attached is the output from my snmpwalk commands.
Danny
Solved! Go to Solution.
02-09-2007 10:22 AM
Have a closer look at your snmpwalk...there are 133 interfaces on this device.
There are no interfaces .91, .111, .125, .135
This is fine too as these interfaces may have been deleted or removed.
02-09-2007 10:22 AM
02-09-2007 11:04 AM
Is it possible for .91, .111, .125, .135 to dissappear (ie. If I reboot the switch?)
-Danny
