Community Member
SNMP OID for PPPoATM active time
I know the show caller command can see how long a PPPoATM session has be up for.
        Active    Idle
  Line           User               Service       Time      Time
  Vi4            vMELBbras10        PPPoATM       05:38:50  00:00:00
Does anyone know what is the correct OID to poll this piece of information?
Andrew
Hello Andrew, Can you try
Hello Andrew,
Can you try this :
 cpmActiveUserID  .1.3.6.1.4.1.9.10.19.1.3.1.1.3
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Community Member
Hi Afroz, Can't find that OID
Hi Afroz,
Can't find that OID.
SNMPv2-SMI::enterprises.9.10.19.1.3.1.1.3 = No Such Object available on this agent at this OID
It is a Cisco 887VAG running 15.3(1)T.
Andrew
33
