Webcast-Catalyst9k
SNMP on Nexus 1000v
I'm having a bear of a time trying to get SNMP to work on a 1000v.  Here's the current SNMP configuration:
show run snmp all
!Command: show running-config snmp all
!Time: Mon Apr 21 10:55:17 2014
version 4.2(1)SV1(5.1)
logging level snmpd 7
snmp-server aaa-user cache-timeout 3600
snmp-server protocol enable
no snmp-server globalEnforcePriv
snmp-server tcp-session auth
snmp-server user admin network-admin auth md5 <redacted> priv <redacted> localizedkey
snmp-server community <redacted> group network-operator
snmp-server community <redacted> use-acl SNMP-V1-RO
 show ip int bri
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
UI-1000v-TEST# show ip int bri vrf all
IP Interface Status for VRF "management"(2)
mgmt0                172.20.255.230  protocol-up/link-up/admin-up
I'm guessing that this has something to do with the fact that I'm using the management vrf for connectivity to the 1000v.  I think the SNMP process is bound to the default vrf.  I fired up ethanalyzer on the 1000v and I can definitely see the SNMP queries hit the 1000v.  It just doesn't respond.  What else do I need to apply to the 1000v in order for it to respond to my SNMP queries?
Everyone's tags (1)
I think I'm hitting a bug.  I
I think I'm hitting a bug.  I have the exact same configuration on other 1000Vs and they are working fine.
Hi, 2 weeks ago, half of mu
2 weeks ago, half of mu N1000V's have become unreachable.  And now, there arre all unreachable.
The only way I found to get around the problem is to remove the ACL.
Marc Lariviere
I forgot.  I had to reboot
I forgot.  I had to reboot N1000V.
233
