snmp query for TenGigE data counters C4510R+E?
Dear community. With the risk of sounding like an idiot I turn to you:
I'm having slight challenges reading the data counters for a ten gigabit Ethernet interfaces on our C4510R+E w/sup8 with this IOS:
bootflash:/cat4500es8-universalk9.SPA.03.03.00.XO.151-1.XO.bin
running snmpwalk on ifindex reveals all indices properly, i.e:
IF-MIB::ifName.1 = STRING: Fa1
IF-MIB::ifName.2 = STRING: Gi1/1
IF-MIB::ifName.3 = STRING: Gi1/2
IF-MIB::ifName.4 = STRING: Gi1/3
…etc…
IF-MIB::ifName.259 = STRING: VLAN-601
IF-MIB::ifName.260 = STRING: VLAN-876
IF-MIB::ifName.261 = STRING: Te5/1--Uncontrolled
IF-MIB::ifName.262 = STRING: Te5/1--Controlled
...etc...
but when trying to see the octet counts from for example ifindex 261 or 262 I get no results at all:
...etc...
IF-MIB::ifHCInOctets.230 = Counter64: 0
IF-MIB::ifHCInOctets.231 = Counter64: 0
NOTE: no ifIndex 261 or 262
IF-MIB::ifHCInOctets.293 = Counter64: 0
IF-MIB::ifHCInOctets.294 = Counter64: 0
...etc...
All other physical interfaces show their values just fine - just not the TenGigE's.
so, dear community: is this a problem, feature or something that can be configured to work differently? or is it just me :-) googling something like "snmp tengigabitethernet counters" brings up mostly problems with the max data rate but in my case the snmp values do not seem to exist at all.
Thanks in advance,
JukkaK
  • Network Management
Everyone's tags (3)
1 ACCEPTED SOLUTION
It may be helpful to see the
It may be helpful to see the entire output/snmpwalk for ifTable and ifXTable for this device to see if all the data is missing for these indexes/TE interfaces.
Many older IOS has some issues where the details for a perticular linecards and its associated interfaces were missing from Switch.
Many times it worked after reseat of Linecard or Reboot of the entire device. As these are not the easy and not the first choice for many, lets check the outputs first.
Also from the switch, please share output for device for show snmp mib ifmib ifindex command.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
-Thanks
Vinod
Thank you Vinod. You pointed
Thank you Vinod. You pointed out the obvious part which I just didn't see.
I'm not supposed to monitor those interfaces with "--(Un)controlled" written next to them. There is proper interface for them instead.
Note to self - when replacing GigE interfaces with TenGigE and then monitoring them with Cacti, remember to reapply suggested interface names to replace old Gi5/1 graph titles with Te5/1. When debugging, I didn't check all the 300+ interfaces of snmpwalk output and assumed that I was looking at the right thing when the last interfaces of the ifIndex snmpwalk output referred to TenGigE ports.
thanks once again Vinod!
"feeling like an idiot" accomplished. over and out.
JukkaK
Jukka,Glad to know that you
Jukka,
Glad to know that you figured out the problem as well as shared the details for other community members to benefit.
Thanks for your contribution.
-Vinod
220
